The camshaft instructions said valve lifter preload should be .030" - .040". I checked #1 exhaust and it was .032". Perfect. With the same pushrod in #7 exhaust, I had .085". I stopped at that point to try to figure out what's going on.
Check all the valve stem ends to see if they're at the same level.
