Left side of the drawing where it says torsion bars, and the lowest arrow points to where it comes out. See the 3 slots where the bar can go into the bracket? Do not do anything at the trunk hinge attaching point while under tension.
If you pry it out and let them fly it will likely just scratch up the paint, not tear up the metal.
