holes in the floor tack it in place drop the whole assy. down then finish weld, push it up to the roof and slide the 6x6 plates under the cage and weld the plates to the cage. only way i know how to get it that tight.
nitrous is like a really hot chick with an std you want to hit it but youre affraid of the outcome.
