Originally Posted By rickseeman
A new hemi block uses a .040 orifice to lube the 8 rocker arms.
The three new world cast iron blocks, wedge and Hemi, I've check had .039 restrictors in thier full time oiling passages to the rocker shafts work shruggyI now use .039 restrictors on all my motors with Indy heads with external oiling on true needle bearing roller rockers up Maybe a little bigger restrictor on bushed or non roller rockers like ductile iron or extruded aluminum with roller tips work
