I just got a moroso one from summit and the instructions show connecting the line for the front brakes to the unit and out of the unit you need a seperate tee fitting to connect the front brake lines to,the front brake lines do not connect to the same block as the back brakes,you have to plug up the hole that the front brake lines off the master cylendar connect to.
