probably are, it has strange hubs, and caliper brackets, and then the wilwood calipers.
question for you guys who have had to do the same thing i am, how do you space the caliper from the rotor, i noticed that they need to be moved just a hair towards the middle of the car on both sides for them to be equally spaced on the rotor? im guessing just thin washers/ shims?
