I have a 78 Chrysler Newport with a 400. The car is my daily driver and I am currently removing the lean burn and replacing it with an electronic ignition and removing the smog equipment. I have a set of non HP exhaust manifolds off a (440) 71 New Yorker I parted out, that I would like to put on the 78 to replace the smog manifolds with air line in the back. Will these manifolds work in this car? I'm not concerned about them bolting up to my current exhaust because I plan to replace the exhaust system anyway. I just want to make sure they will fit in the engine compartment of the 78 with no issues. The log manifolds on the smog cars look different looking than the log manifolds that came on my 71 440 and my 67 440 do they flow any better?
