Originally Posted By Morty426
OK - I'll assume a 71 R/T non shaker
Grill
Headlamp Buckets
Hood - no DODGE letters on the hood in 71
Side scoops
Tail lamps
Tail Finish Panel
Tail Lamp Wiring Harness
The impossible to get 71 DODGE deck lid emblem
You'll need to remove the sheet metal piece that goes between the tail lamps and the rear bumper as 71 does not have that.
That will get you a 10 foot pass
Forgot about those dastardly R/T side scoop....but again he could build a base Challenger N code and forego the side scoops
