Get the `70 to `73 single piston brakes and be sure to use the 11.75 rotors on that heavy car. You will need the bendix disk brake booster too to make it work right. Get a matched set of sway bars and you can upgrade the torsion bars to the 1.06" 1974 chrysler units that came on wagons and some other HD applications. Do not use urethane bushings except on the sway bars unless you want to ruin the quiet smoothe ride that we buy these big cars for.
Very good advice for a C body. Any Chrysler C body disk brakes will bolt right up from 70-73 Make sure you get the 70-73 spindles, caliper brackets, bracket bolts and dust shields, everything else is available from any parts store. I would add - get the HD replacement rear leaf springs from ESPO. The 1.06" torsion bars can be hard to find, but Wildcat auto wreckers has enough donor cars to at least find a set of 1.02"s If you don't get the combination valve from the donor car, www.mpbrakes.com has good stuff.
