Originally Posted By C_stripes
... Why do they have the engine code on there three times (E63, N, 088)?
Good question...
Three different formats for the same info.
E63 is a sales code for 383-4bbl
N is administrative and 'short hand' for 383-4bbl.
In this format, tell only tell you the 'what'; the car got a 383-4bbl.
088 is an assembly code and tells you the 'which'. It tells you which 383-4 engine the car actually received.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
