Quote: I will have the blocked decked. One concern now is the cam selection because I'm keeping the 3.23's for now, but will soon be switching to the 3.91's or even 3.73's.
wait till you figure out what piston you THINK you want to run , if he gets you a piston that is .100 in the hole you DO NOT want to cut that off the deck .
I would consider dropping the extra coin and get a piston to fit a block that was just skimmed to get it back to square .
