Originally Posted By jbc426
Originally Posted By Monte_Smith
GOOD E-85 will be in the .793 area at 60*. The problem with regular E-85 is that it is pump swill and as a result is VERY inconsistent. It can be anywhere from E-55 to E-90 and everywhere in between. Unless you buy it by the drum or mix your own, you will never be guaranteed of its consistency. It's junk fuel, just like any other pump gas
Monte,
Will the Holley Terminator ECU with the added factory style E-85 fuel sensor allow the system to "automatic" adapt to the variation in ethanol content like the flex fuel vehicles do?
No. There is no "flex fuel" programming in the ECU..........Well let me edit that. YES, it can be done in the new V-4 software, but you have to buy some other parts from outside sources
