I am thinking about adding a trans blanket to my 727 equipped small block A body, anybody have any thoughts pro/con? Who makes good one, who makes cheap one. What fitment problems are there? Car is low 12s, no brake, 3600 converter, 6800 rev limiter. I did loose a drive shaft on 2800 rpm launch last run in ’08.
Thanks for any comments!
4bbl If you can't hear it coming what's the point.......
