Can I run the standard MP oil pump distributor gear with the HV pump? Do I need to pull the distributor and oil pump gear to replace the pump. Or can I just pull the oil pump?
(1) I believe so but wait for the BB guys to chime in. (2) I would have the pump bolts barely snug then insert the intergear then final torque the pump bolts for dead on hex alignment. I want to ask what weight of oil are you running? I would want the lightest weight you can get by with & still have adequate psi
