The process for a bonded title here in IL is not so bad, if you have a friend that is a licensed auto dealer registered to sell used cars here in IL, and a friend that can run the numbers through the police data base before parting with your money.
If the panel was ever sold with a lean against it, you will have to seek out that lean holder and have then sign off on it, and if it was ever reported as stolen, it goes back to the person it was stolen from, or their insurance company.
If there is no serial number or motor number, you can't get a bonded title, at least in IL.
Any of the above circumstances exist, they are reason enough to leave the panels stay where they are sitting.
The 1 ton trucks were pretty big, 9' long behind the driver seat, not nearly as desirable as a 1/2 ton, or a 3/4 ton. Definitely wood floors behind the driver seat, can't say about the rest of it. From the hump forward, they are standard pickup ware of the same year, from the hump rearward is humpback specific parts, including the rear fenders (but probably fit several years). The frames are the heavy duty commercial version, rather then the car or light duty pickup. Gene
