In general the cam bearing does not have very high loads. Standard replacement bearings should be fine.
The trick is in installation and adjustment. Cam bearing bores do not always line up just so and the cam may want to bind. They can be line honed, or a used cam with grooves cut in the journals can be used to line them up after install or skillful use of a bearing knife per preference and experience of the builder.
