You want the dimensions of an INDY 360-1 intake gasket opening? Is that correct?
Gasket intake port is 1.36" Wide, 2.16" Tall.... Floor of the port is .610" from bottom edge of the gasket. There's .290" above the roof of the port to the top of the gasket....
