My supplies are not free unfortunately, but certainly cost effective. Three things I still would like to figure out, what does a steel QT housing weigh, so I can see if I am getting any weight benefits, what temps is the housing likely to see from internal heat vs external exhaust, which I can shield ( need this to make sure I use correct epoxy), and then how am I going to contain and fasten the open bottom?
Reality check, that half the population is smarter then 50% of the people and it's a constantly contested fact.
