Originally Posted By savoy64
the 200r has tincan tech on the inside---count on spending up to $2000 on the internal upgrades to get it to live behind a healthy small block--add in adapter costs and it turns into a chunk of change----A500 is the best bet--if you need to build it go with the 999 internals....
Ya savoy, A500 looks like it might be the way to go - financially speaking. Still grinding through a lot of info and appreciate your input.
Fastest 300
