I am not sure either...At this point I just want to be sure that the pressure plate housing is actually neutral balanced.
If they welded on th cover it is most likely NOT neutral balance, and it probably shouldn't be. See my other post.
BTW, McLeod doesn't own that color of red.
I've been running stick shift cars for 50 years and have seen many pressure plate covers with welded on weights from different manufactures. Over those years I have also had a number of engine rotating assemblies balanced. Some wanted the pressure plate to be included , most not. Never, not one asked for a disc.
it's ok to butt heads, just don't do it with a butthead
