Originally Posted By Cab_Burge
Originally Posted By gregsdart
Nice work on those screens up I need to go smaller mesh to stop needle bearings from getting down to the oil pump ,gear drive or oil pump gear. Anybody run anything with smaller mesh? I figured that it might work to put a finer mesh over the screen in the oil pan, but that might not protect the gear drive?
Putting mesh above the roller wheels won't stop the needles from falling out the bottom of the lifter bores, will it workI had two Mopar brand solid roller wheels break in half and get the cam, luckily I shut the motor off before sucking any of the needles bearing up into the oil pump shruggy
Greg has had issues with rocker arm failures and is focused on keeping broken rocker parts contained.
