thanks, where is the best place to trim weight on pistons. On the pin pad, or the pad under the dome, and is it possible to lose 5g off a piston?
You may need all the points you stated, dont take it
from the flat on the bottom of the wrist pin take
it at a 45* angle from the side to the bottom of the
wrist pin. See how thick the under side of the dome/top
is, if you can take it from there
