Originally Posted By okie
Is it just the one seal? There's not one on the center rod ? I"m going to see if I can get what I need today. Thanks Ronnie
Yes.
Originally Posted By JohnRR
but that seal is above the full level so it should not cause the bad leak you say you have.
Will leak when the torque converter drains back.
