Thanks guys, I'm starting to feel better about this. My current springs bind at .75. Sounds like I may need to go to a spring that allows more lift. I also run 1.5 rockers might need 1.6.
Well you aren't going to make a ton of power with 1.50 rocker arms. You have to run a 0.500 lobe lift cam to get .750 valve lift and that is just about the end of the line for a stock Mopar setup. At 0.500 lobe lift you start to run into problems with the oil gallery unless you have bushed lifter bores.
On my EZ heads I run 1.85 Jesel rocker arms and .890 lift. But it takes a serious investment in time and money to make that happen. It is easier to switch heads than to put that much work into a set of EZ heads.
