Originally Posted By Andrewh
I don't know about a 360, but the magnum 5.9 bolted on and ran just fine.
I used the b&m flex plate, that was designed to balance instead of adding weights to the conveter.
been running it for a while now.
There was 1 hole that didn't line up and the brace on one side wouldn't bolt up either. but most people seem to leave that off anyway.
the converter hub was the same size?
i'm not worried about the balance.. i have a b&m flex plate laying around already .
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
