Originally Posted By feets
Originally Posted By Stanton
How does the magic laser get rid of the pitting?
How does the magic laser repair metal that is too thin to weld?
They were working cast iron. That stuff cleans up easy and leaves a decent finish.
You're looking at more than $350,000 for a decent system and then you still have to replace the trashed sheet metal.
"How does the magic laser get rid of the pitting?" - No, Does sanding or sandblasting get rid of the pitting?
"How does the magic laser repair metal that is too thin to weld?" No, does sandblasting or sanding repair metal that is too thin to weld?
Looks to me to be a relatively fast, non destructive, and not to mention MESS FREE alternative to abrasive cleaning.
I'd think asking whether there is usually heat distortion, consumables necessary, are toxic fumes generated, or cost to run (electricity) would be more educated questions. work
Free advice and worth every penny...
Factory trained Slinky rewinder.........
