Time attack, huh. Tough class. Lots of factory money spent in that class by your competitors.
If nothing happens with the engine program it will run TA2, where it is currently entered. If the engine program pans out, we'll switch to TA1 and throw some more modifications at it. Primarily weight, wheels and trans changes. Suspension and aero will remain the same regardless of the class we end up running.
Power is obviously the enemy of any NA motor at altitude, but there is no plan for a blower or turbos at this time.
