So, I got a remanufactured power steering pump and installed it. i also had my TA PS box rebuilt by firm feel to a stage 3.
The box has a lot of slop in it. I also hear that power steering squeal sometimes when I go to turn the wheel. Not a belt squeal but a pump squeal.
Is there a way to check the pump to make sure it has adequate pressure. What is the cause of pump squeal. I know I have sufficient fluid.
Its not easy removing that PS box so I need to eliminate the pump as the problem before taking the box out and sending it back to firm feel.
