In Daytona's photo above of the install kit, the four top clips are the most difficult things to install in the world..
Another clip is made that sets on the shaft and then push it sideways to lock it. Much easier to use and works as good. Go to a local auto glass store, they should be able to help you..
I have spent HOURS trying to get the above clips to work and failed...
So are you talking C clips? I am going to have to pull it all out because all four glass bolts were snapped off so I will know soon what you are talking about. At this point, I don't even know if the little roller wheels need replaced. I guess this gives me a chance to clean it all real good and lube everything as Mike suggested.
