Quote: This is just a suggestion, don't pass on a trunion big block case as all you need is the shaft and the tailhousing to make the conversion. That shaft and housing can come out of a 1965 Poly transmission.
Danny:
I am aware of that, however the tailhousings/shafts are seemingly as hard to find and as expensive as the entire unit!! The sad thing is that I sold off a bunch of this "junk" years ago. If I had it still, I would never need it.
