Those are NHRA weights. Stock weights for both are 720 grams plus pin.
There are two different rod forgings, the 496 and the 645 and they are the same, interchangeable, except for pins, pressed or floating.
Chrysler went to great lengths to make things interchangeable. Their balancing tolerances were pretty wide, as well.
R.
