Originally Posted By Dads426
Rods are the same for all 340's, stock pistons weigh the same; the difference is the compression height between the cast/forged crank 340's. B&M makes a flex plate with the correct scallop for a cast crank motor, or most converters can be ordered with the correct weight.
Crank swap isn't really necessary unless you are pushing it really hard. The cast 340 cranks are pretty stout.
Stock piston weight the same?,,,,if you change the compression height by almost a tenth of an inch from 1.84 to around 1.74...they are going to weight the same?
Tony
70 AARCuda Vitamin C
71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield)
71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas)
71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
