Here are pics I can share from my '65 Satellite.
The strap obviously goes under and installs from front to back (front being at the axle and rear being at the filler neck behind the license plate).
The front (axle) end of the strap has the 'T' shape. This is the "dumb" end and goes into a slot on the subframe. You stick the 'T' in vertically and twists down horizontally into place.
At the rear is where the threaded parts go….
One piece is the threaded bolt with the flattened "mushroom head". The "mushroom head" of this bolt goes into the upside-down-pear-shaped hole on the subframe right under the filler neck pocket.
Then the threaded end that hangs down goes through the hole in the strap, and you put on the nut and tighten it up and it looks like this.
Come back here with any Q's.
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
