You are running what is basically the stock 340 cam, run the 340 valve springs too. Rock auto sells them for a bit less than the recommended kits above, SEALED POWER VS678, $3.30 each.
They say there are no such thing as a stupid question.
They say there is always the exception that proves the rule.
Don't be the exception.
