2JcodeChargers: Yup! All welding, block sanding, painting, wet sanding, etc was done in my 20'x20' garage. Most don't believe it when I tell them that.
minivan: I almost didn't go with the steel wheels and redlines... I do like the Cragars...
68427vette: The Challenger is a 1970 with a '71 grill and tail lights. I will be putting a '70 grill and tail lights back in it. I have been gathering parts for it over the past couple of years. It is going to be BAD......
JcodeCharger: I like the rear wheels you have on your car. I have a set of 15x8 steel wheels that I will probably put a set of M/T Street ET's on eventually.
Mopar_Beach and Matt: It is so close I can taste it!!! I am literally going to smoke those tires right off of that car!
