I did email him and he was responsive. He asked for picts which I haven't given him yet. My fault. Rained bad during the holiday break and I'm overload with work to do it during the daylight hours. It will get solved. Springs are the Thuren 2" soft ride. They were installed at the same time along with the Carli ball joints.
Also called Fox and they will do 1 re-valving for free!
I asked about letting out the nitrogen and they were not so hip? Don't know why? Should of asked more.
Damon
Letting off some nitrogen often softens up the damping a bit and is something you can try without send the shocks in, but the service people at Fox would not tell you to do it as it is a bit bush league, re-valving is the proper way do it.
