Now all I need is a pic of your bars.. but the way
I would put them on is the lower would go on the
bracket you show then if it has a heim joint out
at the wheel for the upper bar I would weld a U type
bracket on the back brace so the upper bar angles
inward... thats how I did my bars.. you can do the same
thing.... you might want to move the upper shock mounts
so the shocks are more vertical to give you a bit more
room for the upper bars.. but they would clear now
wave
