one thing to consider is that raw fuel that washed down cyl walls -ended up- in the oil pan.....naturally , if you thin your oil with gasoline .... well.....---todays fuel injection coupled with excellent piston/ring improvements have almost eliminated that deal...keeping the oil clean is priority #1 in diesel engines and even they have improved over the years.
