tell him to use them as door stops...
buy a set of stealth aluminum heads from 440source.com....or even edelbrock rpms...
by the time you replace the valves..guides ...spring and retainers and pay for the machine work.....you will spend enough to buy the stealth heads at $899.
Not even close Pal!
Grandma always said I had "hands of gold"!
