Re: Short blocks together
[Re: 69CHARGERMD]
#196285
01/20/09 06:37 AM
01/20/09 06:37 AM
Posts: 1,770 Pa
Wv68charger
Pa
Any info on the build for the Charger....eg,,,blocks, heads, changes from previous motor ?
We were there at Norwalk last year rooting you on....car ran great,,,,just curious what changes might be in store...
great car,,,,
Doug
Doug the motor in the pics is the new bullet for the Charger 540 indy maxx somewhere around 14.1cr, heads are the same -1 345s still looking at cams will be a solid roller, T&D 1.6 rockers, X3 intake with a Dom. hoping to run in the low 9.60s
old motor was a 493 11.5cr same heads and intake 1050dom cam was a solid roller i think it was in the 680 range IIRC. We are really hoping that taking the weight off the nose of the car with the alum block will help with weight transfer BG is walking us through this motor (pap and myself) i will post more as the build progress's Still have a lot of work to do hope to see you at one of the CC events this year make sure you stop by and say hi. Allen
