A lot of parts needed
velocity stacks
tach
tack cable
off set master bracket
master cylinder
brake lines
brake valve
line lock
exhaust
headers
water pump
033 radiator
pulleys
carbs
carb linkage
hemi engine harness not sure how the came maybe 383
distributor just will send out and modernize the inside
wires - they do repro them
shock front and rear
I am sure I am missing something
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
