I just had two FP failures too (wouldn't hold 15 psi in the cooling system (PRIOR) to fireup but in all fairness I did extensive cooling hole additions in the decks & I mighta messed up the deck (still ain't figured out what went wrong but I will). maybe I did not chamfer the holes and they needed to be chamfered. those FP's are cheap & I think I would be proactive & spring for new ones
