If you are making any kind of power, I would think you are with a big block. I do not see why a single plane would not work on the street. I have a small block and it will smoke the 315/60 Drag Radials on the street starting off in high gear with a single plane intake.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
