Originally Posted By Clanton
Originally Posted By an8sec70cuda
I hope that was effective. That should have heated the outside of the block plenty, not sure about the cylinder wall.
The water in the block did the heat transfer very well.
Good. up I didn't know you had the block filled w/ water.
CHIP
'06 GMC 2500HD LBZ Duramax
