Is there any difference in the 11" pressure plate between a mopar chevy and ford? If so what are the differences? Its a lot easier to find pressure plate for brand x and y! And let me ask this. Are the bellhousing flywheel specfic to the tooth count (aka 130 teeth flywheel and bellhousing) or can a 11 flywheel and 10.5 flywheel use the same bellhousing/starter teeth count combo?
