I pulled roller cams out of two different engine and replaced them with solid flat tappet cams and both cars were faster with the flat tappet cam. Slightly faster. I don't think you will go faster with a hyd flat tappet, but I bet you wont slow much, two tenths at the most. I would use the old mopar 509 and put it in 6* advanced.
