You can use the LH lower plastic piece, the steering column cover & glovebox door from a non a/c rallye dash car. Only the center lower piece is different for the a/c cars. This has the center a/c vent in it. You will also need the two end vents. I believe these are the same for rallye and non rally dash.
I assume you already know that you will need a rallye dash frame as well.....your non rallye dash frame will not work.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
