I use Dawn also. About 1/2 to 3/4 of a bottle for 2 slicks. 32"x 13.5" x 15", Hoosier. I coat, around the inside. None on the bead. Mine are still holding air from november. In a building , with temperature set at 55*. This is the 5th set, without them leaking down.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
