Having a problem with the left Goodmark inner fender apron. The shelf where the battery tray sits is not flat, when you tighten the tray in place, its 1/2" higher on the inside. Its to bad that this was not noticed before paint. You can't really see it until you install the battery. If we level the tray the battery hits the hood, not sure the best way to fix this. . Heads up to anybody else installing Goodmark inner aprons. Not sure if the AMD have the same problem.
Thats goodmark only? where does year one get theirs? I need to check mine I seem to remember when I bolted the tray on it tipped inward and wasn't flat but have not set a battery on there yet. This may be a tough one to fix? keep me posted on what you do to correct it. thanks javascript:void(0) Dennis
1966 Charger 383 4 speed (Black with Red interior) 1973 Cuda 340 4 speed (Lemontwist) 1972 Corvette
