If it was mine I would run the 360-1 with some port work or the cnc 230s with 2.100 valves.
They fit your pistons and give you some room to the cylinder wall to breathe. Also the castings are happier. A lot of the cnc245s either need to be welded up before you can use them or after a short run time.
